Iphone 6 koppeln über Bluetooth
    also ich nutze eine Iphone 5s mit iOS 8.0.2 und habe keinerlei Probleme im Auto... Verbindung über Blauzahn wird sofort hergestellt und telefonieren geht ebenfalls problemlos... Keine Abbrüche oder ähnliches und Gespräche beenden geht ebenfalls ohne Probleme...
    Shadowmak
  • Hallo Folks,
    nachdem mein iPhone 5 nach dem Update auf IOS 8.02. schwer gesponnen hat, habe ich intensiv nach einer Lösung gesucht...und scheinbar auch gefunden.
    Da es bei mir (zumindest bis soeben) funktioniert hat, möchte ich es hier für alle betroffenen bereitstellen:
    Mit Gruß aus Wien
    Bob
    Quelle: discussions.apple.com
    Here's how:
    Bluetooth:
    1. On your iPhone, go to Settings->Bluetooth and
    "Forget" the device you've been trying to pair with.
    2. On your iPhone, go to
    Settings->iCloud->ShareMyLocation, expand "From", make sure
    "iPhone - This Device" is checked and <swipe left to erase> all
    other devices you no longer use. Exit, go back in and see if the changes are
    saved.
    3. On your iPhone, go to Settings->iCloud and
    "Sign Out" of iCloud on your iPhone (make sure you don't have any
    important files from documents or apps that you're afraid of losing)
    4. On your iPhone, go to Settings->iCloud and re-add
    iCloud to your iPhone following the proper procedure. Afterwards, make sure the
    settings you configured in step #2 are still the same. If they're not, set them
    again.
    5. On your computer, go to icloud.com and login. Click on
    "Find my iPhone". At the top of the screen, click on "All
    Devices" and make sure the list represents ONLY those devices you still
    use. To remove those that you don't use anymore, click on them, and then choose
    the appropriate option to remove that device.
    6. Turn your iPhone off and on.
    If you can’t use a Bluetooth accessory or car kit
    If you updated to iOS 8, have iCloud turned on, and are
    using Bluetooth, you might experience these symptoms:
    ▪ Can’t connect to a Bluetooth accessory,
    like a car kit, car stereo, or headset
    ▪ Can’t make or receive phone calls when
    you’re connected to Bluetooth
    ▪ Can’t hear sound clearly when you’re on a
    call with Bluetooth
    To resolve the issue, you'll need to first sign in to
    iCloud and review your devices:
    1 Sign in to iCloud on your iOS devices.
    2 On one of your devices, tap Settings >
    Bluetooth and look under My Devices. You'll see all devices that are connected
    to Bluetooth, but make sure that you see your Apple devices that are signed in
    to iCloud and are using iOS 8.
    3 Sign out of your iCloud account from any
    devices that you don't want to use. To sign out of iCloud on an iOS device, tap
    Settings > iCloud > Sign Out.
    Then, remove any inactive devices from iCloud:
    1 Sign in to iCloud.com.
    2 Select Find My iPhone.
    3 Select any devices that aren't active
    anymore.
    4 Wait for Find My iPhone to stop trying to
    find the inactive device.
    5 You should see the option to remove this
    device from your account. Select it to remove the device.
    After following the steps above, restart the
    device with the issue. Then try to use it with your Bluetooth accessory.
    7. Try to re-pair your bluetooth and use it.
    I'm sure the next iOS update will address these issues but until then, I hope this works!
  • also bei meinem iphone 6 ging es bis letzt tage noch, dann ist dummer weise einem bekannten runter gefallen (Display im arsch) und seid dem geht nix mehr mit bluetooth sagt mir nur ich soll prüfen ob BMW xxxxx in der nähe ist und auch aktiv ist.... scheiße echt ! hoffe mal das ich Samstag bei Apple direkt ein Austauschgerät bekomme und das es wieder geht -.- :thumbdown:
  • Bei mir mit iOS 8.1 und iPhone 6 alles bestens, allerdings hatte ich von Anfang an keine Probleme, weder mit 8.0 noch mit 8.0.2.
    Wenn jetzt Amazon endlich mal mit meiner Brodit Halterung aus dem Busch kommen würde, wäre das schnieke :)
    Dito, auf die Brodit Halterung warte ich auch schon sehnsüchtig...
    8.1 funzt bei mir jetzt bestens, vorher no way.
  • Wie ist es bei euch mit Nachrichten anzeigen? Mit meinem 5s ging das tadellos, mit dem 6+ leider nicht. Hat das schon jemand geschafft?
