Alles anzeigenHello, sorry it's in English. My German is not so good.
I've got a F31 320dAs with M-suspension.
I want a little drop, so the ACS springs is a good solution I think.
I've measured like shown on the picture on a flat ground (in my garage...), and this are my results:
LV: 377 mm
RV: 370 mm
LH: 368 mm
RH: 360 mm
Is here some one who has got also the ACS springs on a 4 cilinder F31? And how much is the lowering with the ACS?
Thanks in advance!
[Blockierte Grafik: http://i151.photobucket.com/albums/s155/jasiliel/f31/DSC03243_zps1fl5ooc5.jpg~original]
Hi there,
First of all when I wrote deeper in my previous message I of course meant lower... Well what can you expect from a french guy living in Germany trying to post stuff in english...
So I measured the results on my car but unfortunately just the right side, the passenger side.
Front before: 380 mm
Front after: 355 mm
Diff: -25 mm
Rear before: 370 mm
Rear after: 355 mm
Diff: -15 mm
I hope this helps, cheers.
